sr97355
Sep 25, 2022Tutor
Need trouble shooting help for Orbi RBR850 and NVG589
I've been posting on DSL Reports about this issue (see URL: https://www.dslreports.com/forum/r33472738-Troubleshooting-Help) and it was suggested I cross post here as well. We have not been able to...
Sep 26, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
sr97355 wrote:
I've been posting on DSL Reports about this issue (see URL: https://www.dslreports.com/forum/r33472738-Troubleshooting-Help) and it was suggested I cross post here as well. We have not been able to determine if the problem is in the NVG589, the Orbi, or something else. ATT wants me to do a factory reset on the NVG589 and the Orbi, both. But I am reluctant to do that as I have MAC filtering enabled on my Orbi (it will be a pain retyping all that info into the router).
Will be traveling this week and will try to check for posts, but won't have access to the problem equipment until I return home. Maybe redoing all those settings on the Orbi won't be so daunting after I have this little vacation!
