jhamil99
Dec 31, 2020Aspirant
Nest Protect will not connect to Orbi AX4200 RBR750
I just bought an Orbi Mesh systems AX4200 RBR750 and it will not connect to my Nest Protect devices (2nd Gen). Worked ok with Nest Theromostat. I was using the phone app. Any suggestions? Alre...
Dec 31, 2020Guru - Experienced User
Try disabling AX mode on 2.4Ghz under Basic tab/Wireless settings?
Try CTS values to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
- jhamil99Jan 01, 2021Aspirant
My device firware is: V3.2.16.22
The only interface with this device that I am aware of is the app on my phone that I used to install the system. Is there some way to get to these set up/basic/advance settings options from my computer browser? Sorry for my lack of knowledge, I have had an apple time capsule for ~12 years and I never had to do anything to it ever.
- FURRYe38Jan 01, 2021Guru - Experienced User
You need a PC or laptop and web browesr to log into the RBR web page at 192.168.1.1 or orbilogin.com.
