mlzemina
Aug 15, 2022Guide
Nest Thermostat and Nest Video doorbell problem with Orbi RBR350 & satellite RBS350
I've lived with this problem for about a year since I installed a Nest Video doorbell and Nest Learning Thermostat. Each of these disconnects from my mesh Orbi network occasionally. I'm trying to fig...
CrimpOn
Aug 15, 2022Guru - Experienced User
This sounds a lot like problems with the device, rather than something wrong with the home WiFi network (in this case Netgear Orbi).
You have probably researched advice on the internet, such as https://www.smarthomepoint.com/nest-doorbell-offline/
For the thermostat, it might be time to invest $25 in a C-wire product. Try a Google or Amazon search for "power supply for nest thermostat".
mlzemina
Aug 15, 2022Guide
Thanks for that link, I will check it out. Regarding your comment "For the thermostat, it might be time to invest $25 in a C-wire product. Try a Google or Amazon search for "power supply for nest thermostat"." It is C-wire, that is what is strange. When I turn off the switch on the AC/Heater unit I get that there is no power to the thermostat.
