iNexxFear
May 24, 2020Apprentice
Nest Thermostat Batteries LOW on a new ORBI AX setup
I have a brand new ORBI AX wifi setup (RBR850 and 2 satellites) that i got configured and updated to the latest firmware (V3.2.15.25) about 10:00 last night with all nodes up to the version with a bi...
- Oct 03, 2021
No.
Only thing I found was that with mine, being so close to the RBR, 5 feet, was having problems with the NEST. I found that when I moved the RBR away from the one NEST controller, 20-25 feet, the NEST controller started working with out draining the battery. Also was said that this is also a NEST controller issue as well that NEST needs to fix it on there side as these controllers ping pong back and forth on there own when there is more than 1 signal source in play, i.e. RBR and 1 or 2 RBS. Its also recommemeded to install the C power wire to your NEST from the main central AC system to help avoid the battery draining. You'll need to consult your systems mfr wiring diagram to find out which connection that is.
P_Joyce
Aug 06, 2020Aspirant
I followed up with Netgear support on the Nest Thermostat battery drain. Their guidance: The Nest Thermostats connect to the Orbi on 5 GHz which causes the drain. It is not possible to force connection to 2.4 GHz. I ended up connecting my old wireless router to the Orbi as an access point, only on 2.4 GHz with a different SSID and connected the Nest Thermostats to that. They've worked fine for the last several weeks, although it is a little annoying to have to go to this level of workaround.
iNexxFear
Aug 06, 2020Apprentice
If your trying to upgrade your Wi-Fi why should you need to leave 2 in the house to add channel noise? Doesn’t make sense...
And my Nest thermostats connect up to 5ghz just fine with my ASUS Ax11000 ROG router and what I returned back to after returning the hardware. I’ve been fine with this hardware for over a year and never a single battery drain on either thermostats
- P_JoyceAug 06, 2020Aspirant
And, they connected just fine of 5 HGZ on my older Synology and Nighthawk routers.
- FURRYe38Aug 06, 2020Guru - Experienced User
Ya my 2 NESTs work with Orbi AC as well. No issues.
Are you re-charging the NEST controllers before connecting them back to Orbi AX? They need to be re-charged.
I would keep on NG support and ask them to look more into this. Have them contact NEST mfr as well if they haven't already. So far with my 8 series Orbi AX, CTS 64 and 20/40Mhz channel width, I don't see any battery drain. I have seen it only when the NEST controller has disconnected for long periods of time and doesn't connect. I then re-charge the battery.
Possible there maybe some differences between the 7 and 8 series systems that NEST doesn't like.
One thing I do notice is that the 3rd gen seems to not auto reconnect if I make any wifi changes to the RBR. I have to make sure it's re-connected manually.
P_Joyce wrote:And, they connected just fine of 5 HGZ on my older Synology and Nighthawk routers.
- proxy2Aug 06, 2020Aspirant
overnight, battery went to 3.61 and in the morning it got disconnected.
I'm now charging the nest with usb.
next thing, I've setup a mini router under new ssid and it is connected to the ORBI, using my old netgear PR2000
Once nest is fully charged, I'm going to connect it to this mini router and let's see how many days nest will last connected to this router instead.
Ok sounds good.
What are the current values on the Orbi RBR?
CTS?
Channel width?
FW version?
proxy2 wrote:overnight, battery went to 3.61 and in the morning it got disconnected.
my last experience: firmware 32, CTS=64, 2.4ghz=Auto, 5ghz=48
Mon 1pm 3.85V (newly usb charged)
Tue 9am 3.82V (still holding a charge)
Wed 9am 3.74V
Wed 6pm 3.66V (I noticed farsight didn't work)
Thu 8am 3.659 (wifi disconnected)
it appeared that firmware 32, allowed nest to last a little longer (3 days) than previous firmware.
Is 20/40Mhz coexistence enabled or disabled?
And did you notice the battery drain with CTS set to 2347?
proxy2 wrote:my last experience: firmware 32, CTS=64, 2.4ghz=Auto, 5ghz=48
Wed 9am 3.74V
- FURRYe38Aug 07, 2020Guru - Experienced User
Hi,
Can you get us a distance in Ft, between the RBR and NEST controller and distance between the RBS and NEST controller?
I'm getting some informration regarding possible reasons why your NESTs maybe loosing battery power.
- proxy2Aug 08, 2020Aspirant
I can confirm that the problem of battery drain is clearly caused by Orbi
I setup a tiny router, which wireless connects to my orbi and creates a new SSID.
I connected the 3.858V nest to this SSID on Aug6 1pm
it is now 48 hours and battery of the nest is doing fine at 3.848V
Yeah, its lame that I need to run a second router, if orbi releases a firmware that 100% fixes the battery drain issue, please update this topic. Until then, i will have to keep this mini router going for the nest thermostat.
- brandobotAug 08, 2020GuideAlso having this same issue. I setup an old router just for my Nest thermostat. Unacceptable for a $700+ router setup
- brandobotAug 08, 2020GuideRbr from nest is approx 40 ft.
Distance rbs to nest is 10 ft.
On latest firmware - FURRYe38Aug 08, 2020Guru - Experienced User
Thank you for this infromation.
What current CTS values do you have set on the RBR? 64 or 2347?
NG believes there is a ping ponging happening on the NEST and the NEST is some how getting disconnected and attempting to connect to the other signal(RBR) then maybe getting disconnected again then ping ponging it's connection back and forth between the RBS and RBR signal. One thing I do notice with mine, 3rd gen, is that if a change is made on the RBR, the NEST won't auto reconnect and if I don't catch it soon enough, the battery will drain as it gets stuck in the connection non connection loop thus causing the battery to be drained.
10 feet should be close enough, however NG mentioned moving the RBS closer to the NEST controller thats having battery drains to see if this helps any. Let us know the new distance.
I have my 1 3rd gen NEST about 4 feet away from my RBR. I haven't had any problems with this NEST which has been problematic since the introduction of Orbi AX. With v32 FW loaded, I have AX enabled and using 20/40Mhz and CTS at 64. 100% power output and manual channels, 11 and 48 since my next door neighbor has a Orbi AC using lower channels. NEST has been stable and online and no battery drain.
- brandobotAug 08, 2020GuideCts is 2347.
I cant move the rbs any closer, otherwise it’s going to be in my hallway... - FURRYe38Aug 08, 2020Guru - Experienced User
Lets try setting the CTS valued to 64 and set the power out put on the RBR to 50% from 100%. Lets see if we can help keep the NEST near the RBS connected at the RBS.
After you do this, I would disconnect the NEST from the RBS, reboot the NEST, the after it's back online, re-connect it to the RBS signal. Lets see if this helps any.
Also if you don't think the NEST is fully charged, please put a 30 minute charge on it then reconnect it.
- orbi-adanAug 14, 2020Star
I have this exact same issue. Installed FM v32 and moved the satalite as close as possible, but my nest thermostat still keeps dying.
Any updates or solutions anyone has found that worked for them?
- brandobotAug 14, 2020GuideThis is clearly a bug with netgear’s hardware/software. Standard users should not need to jump through hoops to get other devices connected and working properly.
At the rbr850’s price point, it should just work. - FURRYe38Aug 14, 2020Guru - Experienced User
So can we presume that your still having problems with the suggestions given?
If so, please file a support ticket with NG support.
What is the distance between the RBR and RBS? 30 feet or more is recommended.
What is the distance between the NEST controller and the RBR and RBS? How close is the Nest to either unit.
What CTS value are you using on the RBR? 64?
Is 20/40 Coexistence enabled?
Under Advanced Tab/Advanced Settings/Wireless Settings
I'm currently using manual channel 11 and 48 on my RBR. Seems to be working Ok for me. I did see a couple fo disconnects the other day and I had to manually re-connect the NEST.
CTS is 64
20/40Mhz is enabled.
My 3rd gen NEST is 5 feet away from the RBR. This one has been most problematic controller.
My 1st gen NEST is 10-12 feet away from the RBS downstairs, one wall in between.
Make sure you are charging the NESTs fully.
NG believes as I do that the NESTs are failing to re-connect after what ever reason they disconnect. Is this faulure to reconnect to the wifi singal that the NEST keeps ping and trying to connect, thus running the battery down. Also the NEST seems to keep ping ponging back and forth bvetween signals from the RBR and RBS. Then the NEST won't connect at all until it's re-charged. If you don't notice the NEST disconnected in time, then this runs the battery down. I agree, there seems to be issues with NG FW on Orbi. I wish NEST would also change the behavior of the controller to where if it can't get re-connected after a short period of time, it stop's trying and goes into idle or low power mode to save the battery until the user can get it re-connected. Something NEST should also review with NG.
Historically Orbi AX has only been problematic with NEST. My Orbi AC system and other routers I have tried over the years have not seen this issue.
orbi-adan wrote:I have this exact same issue. Installed FM v32 and moved the satalite as close as possible, but my nest thermostat still keeps dying.
- Mikey94025Aug 14, 2020Hero
FURRYe38 wrote:I'm currently using manual channel 11 and 48 on my RBR. Seems to be working Ok for me. I did see a couple fo disconnects the other day and I had to manually re-connect the NEST.
Doesn't sound like it is really working for you either if you have to watch for disconnects or have to manually reconnect.
Several of us have reported issues with our Nest thermostats and the Orbi AX system. No selection of channel or CTS/RTS fixes the problem. We are all running an older router for now to provide compatibility. My nest thermostats worked fine with my Orbi AC system, so Netgear should look more at what could be different between their AX and AC systems. This would be more fruitful than waiting for Nest to do something in their firmware, especially since the Nest is working fine with virtually all other routers right now (including Netgear's other ones). This is going to drive the Orbi AX system away from customers if they are not willing to workaround the problem as the few of us here have.
Telling people to fully charge their Nest, fine tune distances between their satellites, or lower power settings are interesting diagnosis or workaround steps but not solutions. There are many other devices in our home leveraging the wired access point capabilities of these satellites, in their existing locations, and thermostats usually cannot be moved around. We are supposed to benefit from the capabilities of these fancy new mesh routers, not redesign our homes and device locations to fit their quirks,
I'm not trying to tell users to redesign the homes or NEST placements. Trying to help users to see if some of the suggestions and configurations may help the behavior and then get some results and feedback from users having this problem so we can forward this info to NG so they and or NEST can help make changes to either NG Orbi FW and or NEST FW to help both work better and fix these problems.
So far I haven't changed my NEST placement or configuration since v32. What is working is keeping default CTS values and wifi setttings which for me, is working and keeping my NESTs online and not loosing batter life. It's the side effect from what I've seen with my NEST is that the NEST will not reconnect if the connection is lost with Orbi AX and the NEST continues to reconnect causing a battery loss over time if I don't catch the disonnect sooner then later. This seems to be a odd or bad NEST behavior on there part.
Ya, I agree NEST should work with out hassle with Orbi AX. Its been ongoing since I got mine and been working with NG on this as best as I can.
So, Aside from what we already know, any good feedback on results from suggestions given is appreciated so we can pass this on to NG for review. Hopefully they can get it all figured out. There seems to be differences in AX wifi vs AC wifi systems and how things are handled. There needs to be some tuning I presume at some level to get it working well with NEST controllers.
- WilliamGrAug 22, 2020Guide
FURRYe38 wrote:I'm not trying to tell users to redesign the homes or NEST placements. Trying to help users to see if some of the suggestions and configurations may help the behavior and then get some results and feedback from users having this problem so we can forward this info to NG so they and or NEST can help make changes to either NG Orbi FW and or NEST FW to help both work better and fix these problems.
Those settings didn't work for me. Default setup out of the box, and within hours my thermostats are offline. Honestly, who has time to mess with this nonsense when do any other routers have this issue with the Nest thermstats? None that I know of.
- iNexxFearAug 22, 2020ApprenticeNEST work out the issues? Seems like the issue is with Netgear.
- FURRYe38Aug 22, 2020Guru - Experienced User
Then return the Orbi AX system and find something that does.
Good Luck.
WilliamGr wrote:Those settings didn't work for me. Default setup out of the box, and within hours my thermostats are offline. Honestly, who has time to mess with this nonsense when do any other routers have this issue with the Nest thermstats? None that I know of.
- InimicalAug 28, 2020InitiateExperiencing the same issue. Have router and two satellites - all three Nest gen. 3 thermostats in my home have low power warnings and are disconnected from wifi.
