iNexxFear
May 24, 2020Apprentice
Nest Thermostat Batteries LOW on a new ORBI AX setup
I have a brand new ORBI AX wifi setup (RBR850 and 2 satellites) that i got configured and updated to the latest firmware (V3.2.15.25) about 10:00 last night with all nodes up to the version with a bi...
- Oct 03, 2021
No.
Only thing I found was that with mine, being so close to the RBR, 5 feet, was having problems with the NEST. I found that when I moved the RBR away from the one NEST controller, 20-25 feet, the NEST controller started working with out draining the battery. Also was said that this is also a NEST controller issue as well that NEST needs to fix it on there side as these controllers ping pong back and forth on there own when there is more than 1 signal source in play, i.e. RBR and 1 or 2 RBS. Its also recommemeded to install the C power wire to your NEST from the main central AC system to help avoid the battery draining. You'll need to consult your systems mfr wiring diagram to find out which connection that is.
proxy2
Aug 06, 2020Aspirant
my last experience: firmware 32, CTS=64, 2.4ghz=Auto, 5ghz=48
Mon 1pm 3.85V (newly usb charged)
Tue 9am 3.82V (still holding a charge)
Wed 9am 3.74V
Wed 6pm 3.66V (I noticed farsight didn't work)
Thu 8am 3.659 (wifi disconnected)
it appeared that firmware 32, allowed nest to last a little longer (3 days) than previous firmware.
Aug 06, 2020Guru - Experienced User
Is 20/40Mhz coexistence enabled or disabled?
And did you notice the battery drain with CTS set to 2347?
proxy2 wrote:my last experience: firmware 32, CTS=64, 2.4ghz=Auto, 5ghz=48
Wed 9am 3.74V
