iNexxFear
May 24, 2020Apprentice
Nest Thermostat Batteries LOW on a new ORBI AX setup
 I have a brand new ORBI AX wifi setup (RBR850 and 2 satellites) that i got configured and updated to the latest firmware (V3.2.15.25) about 10:00 last night with all nodes up to the version with a bi...
- Oct 03, 2021
No.
Only thing I found was that with mine, being so close to the RBR, 5 feet, was having problems with the NEST. I found that when I moved the RBR away from the one NEST controller, 20-25 feet, the NEST controller started working with out draining the battery. Also was said that this is also a NEST controller issue as well that NEST needs to fix it on there side as these controllers ping pong back and forth on there own when there is more than 1 signal source in play, i.e. RBR and 1 or 2 RBS. Its also recommemeded to install the C power wire to your NEST from the main central AC system to help avoid the battery draining. You'll need to consult your systems mfr wiring diagram to find out which connection that is.
orbi-adan
Aug 31, 2020Star
I have been in comminication with tier 2 support. They have now escalated this issue to engineering. At the moment there is no solution. I will post back if I hear anything.
iNexxFear
Aug 31, 2020Apprentice
Well I wouldn’t put any money on that and due to the limited assistance and warranty you’d be best to pack it up and return it. My posting for this was 3 months ago when this happens and NOW they are JUST looking to put it up to engineering?
Seriously. And it’s coming hearing season. This seems more than unacceptable and should have been addressed a long time back. OR it shouldn’t have existed to begin with seeing it never happens with the prior models.
