iNexxFear
May 24, 2020Apprentice
Nest Thermostat Batteries LOW on a new ORBI AX setup
I have a brand new ORBI AX wifi setup (RBR850 and 2 satellites) that i got configured and updated to the latest firmware (V3.2.15.25) about 10:00 last night with all nodes up to the version with a bi...
- Oct 03, 2021
No.
Only thing I found was that with mine, being so close to the RBR, 5 feet, was having problems with the NEST. I found that when I moved the RBR away from the one NEST controller, 20-25 feet, the NEST controller started working with out draining the battery. Also was said that this is also a NEST controller issue as well that NEST needs to fix it on there side as these controllers ping pong back and forth on there own when there is more than 1 signal source in play, i.e. RBR and 1 or 2 RBS. Its also recommemeded to install the C power wire to your NEST from the main central AC system to help avoid the battery draining. You'll need to consult your systems mfr wiring diagram to find out which connection that is.
WilliamGr
Sep 20, 2020Guide
Agree. I already ready returned mine to Costco.
FDohadwala
Sep 25, 2020Initiate
We are facing similar issues (low battery) with Nest since we installed Orbi Mesh 6 router. Looks like this is a known issue. Plan to follow this thread, lot of good information. I will
WilliamGr wrote:Agree. I already ready returned mine to Costco.
open a case with Netgear.
- iNexxFearSep 25, 2020ApprenticeThe biggest suggestion is to just return don’t bother with Netgear, they did nothing when I first experienced this and your heading into heating months. Unless you have a wire to keep the nest charged otherwise you are ready for headaches
- WilliamGrSep 25, 2020Guide
FDohadwala wrote:We are facing similar issues (low battery) with Nest since we installed Orbi Mesh 6 router. Looks like this is a known issue. Plan to follow this thread, lot of good information. I will
Just send it back. There's no point at this stage hanging around. This was first mentioned 4 or 5 months ago and Netgear don't seem interested in fixing it. If they had even said they have replicated the issue and are working to fix it, I'd have kept mine - but nope. Just "can we get your serial number" messages, which tells me they have no clue. This affects all of them.
