iNexxFear
May 24, 2020Apprentice
Nest Thermostat Batteries LOW on a new ORBI AX setup
I have a brand new ORBI AX wifi setup (RBR850 and 2 satellites) that i got configured and updated to the latest firmware (V3.2.15.25) about 10:00 last night with all nodes up to the version with a bi...
- Oct 03, 2021
No.
Only thing I found was that with mine, being so close to the RBR, 5 feet, was having problems with the NEST. I found that when I moved the RBR away from the one NEST controller, 20-25 feet, the NEST controller started working with out draining the battery. Also was said that this is also a NEST controller issue as well that NEST needs to fix it on there side as these controllers ping pong back and forth on there own when there is more than 1 signal source in play, i.e. RBR and 1 or 2 RBS. Its also recommemeded to install the C power wire to your NEST from the main central AC system to help avoid the battery draining. You'll need to consult your systems mfr wiring diagram to find out which connection that is.
samnt650
Dec 09, 2020Tutor
RBR850 & two RBS850. Firmware v3.2.16.22
Like everyone, NEST 3rd Gen keep dying from low battery since I switch to Orbi. Put the NEST back to Nighthawk and problem disappeared. Agreed with previous post, this is specific to the Orbi product. I tried mess with CTS/RTS setup, on/off with the AX setup, cannot fix the NEST low battery problem.
Dec 09, 2020Guru - Experienced User
Also what is the FW/SW version seen on your 3rd gen NEST controller?
samnt650 wrote:RBR850 & two RBS850. Firmware v3.2.16.22
