iNexxFear
May 24, 2020Apprentice
Nest Thermostat Batteries LOW on a new ORBI AX setup
I have a brand new ORBI AX wifi setup (RBR850 and 2 satellites) that i got configured and updated to the latest firmware (V3.2.15.25) about 10:00 last night with all nodes up to the version with a bi...
- Oct 03, 2021
No.
Only thing I found was that with mine, being so close to the RBR, 5 feet, was having problems with the NEST. I found that when I moved the RBR away from the one NEST controller, 20-25 feet, the NEST controller started working with out draining the battery. Also was said that this is also a NEST controller issue as well that NEST needs to fix it on there side as these controllers ping pong back and forth on there own when there is more than 1 signal source in play, i.e. RBR and 1 or 2 RBS. Its also recommemeded to install the C power wire to your NEST from the main central AC system to help avoid the battery draining. You'll need to consult your systems mfr wiring diagram to find out which connection that is.
turbojimmy2
May 20, 2021Guide
I'm having the same issue. Both thermostats die. I've been charging them with USB cables for months now. They're on different floors and each are pretty close (within 20 feet) of the base and satellite. Base is on the first floor, satellite is on the second floor almost directly above it. Firmware is up to date.
Do I bother calling support on this? Can they offer any help?
samnt650
May 20, 2021Tutor
Move either the base or satelite as far away from the Thermostat as possible. OR shutdown your Satellite. Your NEST is flopping between AP draining the battery.
- turbojimmy2May 20, 2021Guide
samnt650 wrote:>> They're on different floors and each are pretty close (within 20 feet) of the base and satellite
The problem is that I have 3 floors to cover. The base is on the top floor and the satellite is on the middle floor.
Coverage is awesome so I don't want to mess it up becuase of the thermostats.
I guess I have to dust off an old router to fix this which seems stupid.
Is this a Nest problem or a Netgear problem?
- samnt650May 20, 2021Tutor
Neither. Both AP & NEST are doing exactly what Wifi mesh designed to do. if you dont want to move the router or sat. then put a metal shield on one of the device. Idea is to make the uni directional signal appear weaker toward your NEST. This should slow down the AP hopping.
- turbojimmy2May 21, 2021GuideThanks for that. I think I’ll just use an old router for the Nest. It’s frustrating because I didn’t have this issue with the Google pucks that were pretty much in the same exact locations.
