iNexxFear
May 24, 2020Apprentice
Nest Thermostat Batteries LOW on a new ORBI AX setup
I have a brand new ORBI AX wifi setup (RBR850 and 2 satellites) that i got configured and updated to the latest firmware (V3.2.15.25) about 10:00 last night with all nodes up to the version with a bi...
- Oct 03, 2021
No.
Only thing I found was that with mine, being so close to the RBR, 5 feet, was having problems with the NEST. I found that when I moved the RBR away from the one NEST controller, 20-25 feet, the NEST controller started working with out draining the battery. Also was said that this is also a NEST controller issue as well that NEST needs to fix it on there side as these controllers ping pong back and forth on there own when there is more than 1 signal source in play, i.e. RBR and 1 or 2 RBS. Its also recommemeded to install the C power wire to your NEST from the main central AC system to help avoid the battery draining. You'll need to consult your systems mfr wiring diagram to find out which connection that is.
Jun 16, 2021Guru - Experienced User
Enjoy.
turbojimmy2
Jun 19, 2021Guide
Well it took a week after I installed the Nest power adapter, but now my downstairs thermostat is offline due to low power.
I guess I'll have to set up a secondary WiFi network for the thermostats.
- FURRYe38Jun 19, 2021Guru - Experienced User
So the adapter is NOT working?
turbojimmy2 wrote:Well it took a week after I installed the Nest power adapter, but now my downstairs thermostat is offline due to low power.
- turbojimmy2Jun 19, 2021Guide
FURRYe38 wrote:So the adapter is NOT working?
I think the adapter is working, but it's not enough to keep the thermostat charged. It took a week for it to die instead of a couple days.
Seems like the adapter should be keeping the NEST charged from what I understand.
