iNexxFear
May 24, 2020Apprentice
Nest Thermostat Batteries LOW on a new ORBI AX setup
I have a brand new ORBI AX wifi setup (RBR850 and 2 satellites) that i got configured and updated to the latest firmware (V3.2.15.25) about 10:00 last night with all nodes up to the version with a bi...
- Oct 03, 2021
No.
Only thing I found was that with mine, being so close to the RBR, 5 feet, was having problems with the NEST. I found that when I moved the RBR away from the one NEST controller, 20-25 feet, the NEST controller started working with out draining the battery. Also was said that this is also a NEST controller issue as well that NEST needs to fix it on there side as these controllers ping pong back and forth on there own when there is more than 1 signal source in play, i.e. RBR and 1 or 2 RBS. Its also recommemeded to install the C power wire to your NEST from the main central AC system to help avoid the battery draining. You'll need to consult your systems mfr wiring diagram to find out which connection that is.
Crawfordiii
Nov 09, 2021Aspirant
I tried the same thing and it worked! Battery level keeps charging as mine is connected to the C wire. We will see if it holds once I do that for my other Nest Learning Thermostat. Ridiculous that neither company of the two most highly rated products in their prospective categories can't or won't solve this!
Nov 09, 2021Guru - Experienced User
Whats the distance between the RBR, RBS and your NEST controllers. I found that distance can be a factor.
Current working version of FW that seems to work with my 1 3rd gen NEST is v3.16. No low battery was seen with my 8 series Orbi.
