rel234
Dec 04, 2021Tutor
Netatmo Welcome camera issues with Orbi RBR752 (RBR750 router and RBS750 satellite)
This post is mostly to remember solution myself and maybe help someone else as I couldn't find anything in previous posts when faced these issues... I have used Netatmo Welcome camera with different...
rel234
Dec 05, 2021Tutor
Changing CTS/RTS and disabling AX mode did not have any effect in my case - Netatmo Welcome camera kept disconnecting. Problem was solved only by changing preamble to Long.
Dec 06, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
