Retired_Member
May 08, 2021Netgear Armour
Hi. Just after a bit of information. I want to setup an Orbi RBK753 system but without the Netgear Armour. Can I set up the 753 without accepting the Netgear Armour trial as I do not want it? I don...
May 08, 2021Guru - Experienced User
There is a mouse selection on the Armor popup window that you select "Never how this again".
Retired_Member
May 10, 2021Thanks for replying.
