hackeravoider06
Jan 15, 2025Aspirant
Netgear AX1800 RBK352 Dual-band Mesh Wifi 6 System 5G wifi cannot be turned off
Hi everyone, I have one serious concern regaring the risks associated with the product Netgear AX1800 RBK352 Dual-band Mesh Wifi 6 System. As per chatting with technical support, it appears that N...
Jan 15, 2025Guru - Experienced User
Orbi systems don't allow of disabling of any of the wifi radios.
As per chatting with technical support, it appears that Netgear does not allow the 5G wifi to be turned off. The advantage of 5G wifi was emphasized by the support. The speed is fast! (Actually I do not care about it. 330Mb/s is enough for me).
It does not explain why the function of turning off 5G is there. The 5G wifi can never be turned off even if it had been manually turned off on the desktop. When you checked Orbi APP, the 5G will always be there.
5G wifi faciliate the hackers to enter into your computers. It is really a risk.
I have ever used other brands of modern. The 5G wifi can be easily turned off. It allow the users to use 2.4G wifi only.
Is it a bug that was unnoticed by Netgear Orbi? Thank you
