bamer02
Aug 20, 2022Aspirant
Netgear CM2000 combined with Orbi RBR750
Hello I moved 4 months ago and transferred my Spectrum account to the new address. During the same time, Spectrum had a deal and upgraded me to a 1GB speed plan. I had actually forgotten abo...
Aug 20, 2022Guru - Experienced User
No.
Check your speed with Ooklas installable speed test app on the laptop.
If the laptop is wirelessly connected to the RBR or RBS, most likely you'll never see anything near 900Mbps. Depends on wifi design and support of the wifi device. Most top out at around 300-600Mpbs depending.
What is the mfr and model# of the wifi adapter in the laptop?
Speed test with the laptops ethernet adapter connected to the back of the RBR...
