Puch96
Mar 30, 2021Guide
Netgear CM2000 has blinking white downstream light
Hello. I was wondering if anyone is experiencing an issue with Netgear CM2000 cable modem on Xfinity. My downstream light will blink white. I do not have any connection issues, but I notice the fo...
Mar 30, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the cable modem product. Most of the people who watch that forum are more likely to have experience with cable modem and know how to work it better than those of us who follow this "Orbi AX" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
