Puch96
Mar 30, 2021Guide
Netgear CM2000 has blinking white downstream light
Hello. I was wondering if anyone is experiencing an issue with Netgear CM2000 cable modem on Xfinity. My downstream light will blink white. I do not have any connection issues, but I notice the fo...
JackyShen
Apr 06, 2021Aspirant
It seems the signal have a few noise but it will not effect too much because it come back quickly.
The LED issue may the software issue. I guess....
From D3.1 Spec
Type 20: NCP profile failure.
Type 22: NCP profile recovery.
Apr 06, 2021Guru - Experienced User
Please post about this here:
Thanks
JackyShen wrote:It seems the signal have a few noise but it will not effect too much because it come back quickly.
From D3.1 Spec
