Puch96
Mar 30, 2021Guide
Netgear CM2000 has blinking white downstream light
Hello. I was wondering if anyone is experiencing an issue with Netgear CM2000 cable modem on Xfinity. My downstream light will blink white. I do not have any connection issues, but I notice the fo...
Southxpaw
Jun 08, 2021Aspirant
Hi, I also bought a netgear cm2000. This is actually my 2nd one. My first modem worked for about A month and a half. One day it just shut off and never came back on and so I got it replaced. But on both modems, the downstream icon keeps blinking. It’s very annoying. Has there been a fix for it?
Jun 08, 2021Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
