rxtxusa1
Aug 09, 2023Follower
Netgear Nighthawk CM2000 Cable Modem & Netgear Orbi RBR850
The app shows “No Internet Connection Available”, yet the app speed test runs a 350mBps - bottom line - the router outputs nothing. Can anyone help me with this dilemma.
1 Reply
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.What Firmware version is currently loaded?
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
