RAPA
Sep 08, 2020Aspirant
Netgear Orbi and MacBook Pro
Orbi Wifi 6 router (RBR850) frequently disconnects with the new MacBookPro. Interestingly, a friend of mine has the same combination and he is experiencing the same problem. It's frustrating that $60...
Sep 15, 2020Guru - Experienced User
What model Mac do you have?
What OSX version are you using?
What distance is the mac book from the RBR?
Is there a RBS850 online as well?
Does changing from CTS 64 to 2347 help any Under Advanced Tab/Advanced Settings/Wireless Settings
RAPA wrote:Orbi Wifi 6 router (RBR850) frequently disconnects with the new MacBookPro. Interestingly, a friend of mine has the same combination and he is experiencing the same problem. It's frustrating that $600 router doesn't work and warranty on the product is very bad.
- RAPASep 16, 2020Aspirant
Orbi firmware version is V3.2.16.6
ISP os Comcast.
Modem model is ARRIS Group, Inc. TG3482G.
MacBook Pro. model is 2.0GHz Quad-Core Processor with Turbo Boost up to 3.8GHz, 512GB Storage, Touch Bar and Touch ID. Bought July 2020.
Location doesn't seem to matter - I've kept the modem at the line of sight, same floor different room and different floor. Same issue
Channel is set to Auto.
- FURRYe38Sep 16, 2020Guru - Experienced User
What mode is your Arris modem working in Router or Modem only? If router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModeWhat happens if you change CTS values from 64 to 2347 under Advanced Tab/Advanced Settings/Wireless Settings or disable AX mode on the RBR...
All radio/wiifi on the modem is disabled. The cable modem/router is set to run on Bridge mode.
Where do i set the following?
