RAPA
Sep 08, 2020Aspirant
Netgear Orbi and MacBook Pro
Orbi Wifi 6 router (RBR850) frequently disconnects with the new MacBookPro. Interestingly, a friend of mine has the same combination and he is experiencing the same problem. It's frustrating that $60...
Sep 15, 2020Guru - Experienced User
What model Mac do you have?
What OSX version are you using?
What distance is the mac book from the RBR?
Is there a RBS850 online as well?
Does changing from CTS 64 to 2347 help any Under Advanced Tab/Advanced Settings/Wireless Settings
RAPA wrote:Orbi Wifi 6 router (RBR850) frequently disconnects with the new MacBookPro. Interestingly, a friend of mine has the same combination and he is experiencing the same problem. It's frustrating that $600 router doesn't work and warranty on the product is very bad.
RAPA
Sep 16, 2020Aspirant
Orbi firmware version is V3.2.16.6
ISP os Comcast.
Modem model is ARRIS Group, Inc. TG3482G.
MacBook Pro. model is 2.0GHz Quad-Core Processor with Turbo Boost up to 3.8GHz, 512GB Storage, Touch Bar and Touch ID. Bought July 2020.
Location doesn't seem to matter - I've kept the modem at the line of sight, same floor different room and different floor. Same issue
Channel is set to Auto.
- FURRYe38Sep 16, 2020Guru - Experienced User
What mode is your Arris modem working in Router or Modem only? If router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModeWhat happens if you change CTS values from 64 to 2347 under Advanced Tab/Advanced Settings/Wireless Settings or disable AX mode on the RBR...
- RAPASep 16, 2020Aspirant
All radio/wiifi on the modem is disabled. The cable modem/router is set to run on Bridge mode.
Where do i set the following?
Orbi is set to router mode
