RAPA
Sep 08, 2020Aspirant
Netgear Orbi and MacBook Pro
Orbi Wifi 6 router (RBR850) frequently disconnects with the new MacBookPro. Interestingly, a friend of mine has the same combination and he is experiencing the same problem. It's frustrating that $60...
Sep 16, 2020Guru - Experienced User
What mode is your Arris modem working in Router or Modem only? If router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
What happens if you change CTS values from 64 to 2347 under Advanced Tab/Advanced Settings/Wireless Settings or disable AX mode on the RBR...
RAPA
Sep 16, 2020Aspirant
All radio/wiifi on the modem is disabled. The cable modem/router is set to run on Bridge mode.
Where do i set the following?
- RAPASep 16, 2020Aspirant
Orbi is set to router mode
- FURRYe38Sep 16, 2020Guru - Experienced User
On the RBRs web page. Follow the path that I mentioned to find that setting.
AX mode is on the Basic TAB/Wireless settings page on RBR.
"What happens if you change CTS values from 64 to 2347 under Advanced Tab/Advanced Settings/Wireless Settings or disable AX mode on the RBR..."
What does this do? Should i change the CTS values both 2.4 GHZ and 5GHZ?
Also, what does disabling Ax feature do?
