RAPA
Sep 08, 2020Aspirant
Netgear Orbi and MacBook Pro
Orbi Wifi 6 router (RBR850) frequently disconnects with the new MacBookPro. Interestingly, a friend of mine has the same combination and he is experiencing the same problem. It's frustrating that $60...
RAPA
Sep 16, 2020Aspirant
All radio/wiifi on the modem is disabled. The cable modem/router is set to run on Bridge mode.
Where do i set the following?
What happens if you change CTS values from 64 to 2347 under Advanced Tab/Advanced Settings/Wireless Settings or disable AX mode on the RBR...
RAPA
Orbi is set to router mode
