Misterkeg
Nov 23, 2020Aspirant
Netgear Orbi AX4200 New set Up
Well, I just set up my new Orbi AX4200 Mesh wifi system in my home. After watching Youtube videos concerning the set up, and reading articles online, it was finally the time to get it done. I was rep...
Nov 23, 2020Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
I recommmend setting up the system using a wired or wireless PC or laptop and web browser pointed at orbilogin.com or 192.168.1.1
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
Is Armor enabled?
- MisterkegNov 23, 2020Aspirant
Yes, Armor is enabled. Is it anygood? I've been getting a couple of messages it had blocked potential spam, but other than that, I haven't noticed anything good or bad about having the Armor installed. I don't know what they charge for it after the 1 year free trial, but I guess I'll wait and see how well it works. Thanks for all the tips in your message, It's up and running and everything is working as intened.
- FURRYe38Nov 23, 2020Guru - Experienced User
Been a mixed bag. See posts that it seems to cause problems for some.
I would try disabling Armor, once you applied the change, power OFF the RBR for 15 seconds then back on then check again...
- MisterkegNov 24, 2020Aspirant
I was having problems connecting to an older HP OFFICEJET over my Orbi WiFi network, so then I disabled the Armor security software, saved the change, and was able to print again. When you mentioned rebooting the RBR after making the change (shutting off Armor), what is the RBR? By shutting off, do you mean rebooting on the Orbi app, or disconnecting from the power source? Thanks again.
