Misterkeg
Nov 23, 2020Aspirant
Netgear Orbi AX4200 New set Up
Well, I just set up my new Orbi AX4200 Mesh wifi system in my home. After watching Youtube videos concerning the set up, and reading articles online, it was finally the time to get it done. I was rep...
Misterkeg
Nov 24, 2020Aspirant
I was having problems connecting to an older HP OFFICEJET over my Orbi WiFi network, so then I disabled the Armor security software, saved the change, and was able to print again. When you mentioned rebooting the RBR after making the change (shutting off Armor), what is the RBR? By shutting off, do you mean rebooting on the Orbi app, or disconnecting from the power source? Thanks again.
Nov 24, 2020Guru - Experienced User
I recommemd Power OFF the RBR=Orbi router, then power it back ON after disabling Armor. Don't just reboot it.
