JRiffle
Jul 01, 2021Follower
Netgear Orbi AX4200
Got a Sleep Number Bed and have the Sleep IQ App but not able to pair due to Sleep IQ not able to connect to 5G. Checked with Spectrum Internet Provider who send commands to reset the modem. Evidentl...
gary_lee
Aug 09, 2021Aspirant
Same problem with Sleep Number here. RBR750. I've tried disabling 5ghz and shutting off my sattelite, no luck.
This worked fine earlier.
Gary
Aug 09, 2021Guru - Experienced User
I would contact the mfr of this devices and get help from them on there product.
Might temporarily disable WPA security on the RBR, and see if the device connects. Re-enable WPA or mixed mode WPA/WPA2 and see what happens.
Gary
