RehanSaeed
Sep 29, 2021Aspirant
Netgear Orbi AX6000 - Open VPN Not Connecting While on Wifi
I have enabled DDNS and OpenVPN on my Netgear Orbi AX6000 and am able to use the Open VPN Android app to connect while on my mobile network. However, as soon as I connect to the WiFi, the app can no ...
Sep 29, 2021Guru - Experienced User
- RehanSaeedSep 29, 2021Aspirant
Firmware version: V4.6.3.16_2.0.51
ISP: BT Fibre
ISP Modem: The fibre cable runs into a small wallmounted box which I guess is the ISP modem. I then have an RJ45 cable going into the Orbi.
- FURRYe38Sep 29, 2021Guru - Experienced User
Turn OFF the RBS. Connect your mobile device to the RBR only and check.
Is Armor or IPv6 enabled on the RBR?- RehanSaeedSep 30, 2021Aspirant
Turned off the satelite router and that didn't help. I also had Armor and IPv6 enabled. When I also turned those off, that didn't help either.
