solosys
Aug 11, 2022Aspirant
Netgear Orbi AXE11000 with Quantum Fiber
Thinking about upgrading from Spectrum 350Mbps to Quantum Fiber 1Gbps service. I want to make sure the AXE11000 will work right out the box or do I have to coordinate with the ISP to get everything co...
Aug 11, 2022Guru - Experienced User
I recommend contacting the ISP and asking them if there equipment can be bridged or if not can the wifi be fully disabled.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
solosys
Sep 01, 2022Aspirant
Well, my install is happening this afternoon. After talking to the technician a few weeks ago, he said the transition should be seamless. He mentioned their new equipment does auto vlan id's and such so I don't need to do anything to my Orbi router. I'll follow up with another post.
- FURRYe38Sep 01, 2022Guru - Experienced User
- solosysSep 01, 2022AspirantDone deal!! Install was seamless. Just had the Orbi routet powered off while the Quantum modem initialized, I then powered on the Orbi router. Didn't even have to do anything with the Orbi settings or with the satellites.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
