solosys
Aug 11, 2022Aspirant
Netgear Orbi AXE11000 with Quantum Fiber
Thinking about upgrading from Spectrum 350Mbps to Quantum Fiber 1Gbps service. I want to make sure the AXE11000 will work right out the box or do I have to coordinate with the ISP to get everything co...
solosys
Sep 01, 2022Aspirant
Well, my install is happening this afternoon. After talking to the technician a few weeks ago, he said the transition should be seamless. He mentioned their new equipment does auto vlan id's and such so I don't need to do anything to my Orbi router. I'll follow up with another post.
Sep 01, 2022Guru - Experienced User
- solosysSep 01, 2022AspirantDone deal!! Install was seamless. Just had the Orbi routet powered off while the Quantum modem initialized, I then powered on the Orbi router. Didn't even have to do anything with the Orbi settings or with the satellites.
- FURRYe38Sep 01, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
