MattTweddell
May 21, 2021Follower
Netgear Orbi Issues
Hi all, Im having an issue with an Orbi system that contains 1 x RBR750 and 3 RBS750 satellites. The property isn't huge, yet the signal to one of the satellites consistently drops, which isnt us...
May 21, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
I would directly connect the one RBS to the back of the RBR to see if it syncs and connects correctly to the RBR and maintains the connection. if it does, I would suspect your power line device thats in between the RBR and RBS would be the cause of what your seeing.
