Paolo_Coppi
Mar 02, 2022Tutor
NETGEAR Orbi Mesh WiFi 6 RBK752, wireless region set to "China" but system bought in Italy
Hello, I purchased the NETGEAR Orbi Mesh WiFi 6 RBK752 in Italy on Amazon but the region of the Wi-Fi is set to China without the ability to change it from Advanced -> Advanced -> Wireless Settin...
Mar 02, 2022Guru - Experienced User
Some regions lock their region settings.
If yours is locked to the wrong region, you'll probably need/want to exchange it.
You used to be able to telnet in and change it with the burnsku command but telnet was locked out as well as I think it voids a warranty.
