Philou73
Jul 27, 2021Aspirant
Netgear Orbi RBK353 : Internet WAN disconection
Since the installation of the Orbi RBK353 system (base + 3 satellites), I have internet cuts several times a day and it takes between 5 and 10 minutes to come back ... Quite frustrating when we do te...
Jul 27, 2021Guru - Experienced User
Is the front of the RBRs LED turning ON when this happens when loosing internet?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
If so, then something between the RBR and the host router is loosing the connection and the RBR is being effected. The Orbi in AP mode is only passing data thru and relies on good connection from the upstream host router.
Be sure to swap LAN cables between the RBR and the host router. CAT6 is recommended.
Be sure your using the WAN port on the RBR as the connection to the host router upstream from the RBR.
Connect a wired PC to this host router with out the RBR online to see if the problem appears also at the PC connected this router. If it does, you'll need to contact the ISP and let them know about this.
Philou73
Hi
Firmware is V4.3.4.8_1.9.53
When it shut down , the orbi router is pulsing magenta
On the Proximus modem, all lights are correct and seems to be OK.
During the cut off, I connect in LAN a laptop and internet is working.
Connection is from WAN connector Modem to INTERNET connector on the Orbi.
The cable use is the one deliver with the Orbi kit.
Philippe
- FURRYe38Jul 27, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Is the RBR placed near other electronic devices?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a factory reset and setup from scratch been performed since last FW update?
- Philou73Jul 27, 2021Aspirant
Hi
The issue seems to be between the Modem and the Orbi router.
The application Orbi said 'INTERNET HORS LIGNE'
The WIFI Signal is still working as, during internet cut, I have access to my network and Proximus TV is working.
The TV decoder is connected to a satellite and signal is working.
Philippe
Please give feedback to the question presented.
Do you have a prior router that you can try connected to the mode to see if this follows?
