murbanski
Aug 10, 2022Aspirant
Netgear Orbi RBK752 AX4200 tri-band mesh - local DHCP DNS setup for PiHole
Hello, I would like to have an access to the setting that allows me to setup DNS IP for my local DHCP server. I need to provide my raspberryPi's IP address as an primary DNS served from DHCP. Curren...
CrimpOn
Aug 10, 2022Guru - Experienced User
The Pi-hole can be the DHCP server. Turn off the DHCP option on the Orbi.
- murbanskiAug 10, 2022Aspirant
Well, this is an option. But I am still wondering why can't they add this functionality to this overpriced router?
I would really prefer to use my router as a router and not relay on any 3rd party software. My concern is that my network will stop working if anything happens to my raspberry Pi. Anything, hardware failure, maintenance, etc.- CrimpOnAug 10, 2022Guru - Experienced User
With the Pi-hole providing DNS, anything that takes Pi-hole down takes down the whole network, whether the Orbi router is directed to use the Pi-hole or individual devices are directed to it by DHCP. Without DNS, the network becomes unusable. That is why users who implement Pi-hole typically have redundant Pi's.
There is a world of difference between what the engineers can do to the router and what they have decided to do.
- Offer the option for different SSIDs for 2.4G and 5G. Nope.
- Offer an option to schedule the WiFi radios to turn on/off according to a schedule. Nope.
- Provide usage statistics by device. Nope.
- Offer the option to enable/disable broadcasting SSIDs. Gone when the original Orbi was replaced by the AX products.
- Offer the ability to enable/disable features like MIMO, Fast Roaming, etc. Gone.
- Provide a method to force devices to connect to specific access points. Nope.
- Offer the option to enable/disable automatic firmware updates. Nope.
I lead a pretty sheltered life, but I cannot recall ever seeing a router with the ability to configure what DNS server was specified in the DHCP contents.
