murbanski
Aug 10, 2022Aspirant
Netgear Orbi RBK752 AX4200 tri-band mesh - local DHCP DNS setup for PiHole
Hello, I would like to have an access to the setting that allows me to setup DNS IP for my local DHCP server. I need to provide my raspberryPi's IP address as an primary DNS served from DHCP. Curren...
Aug 11, 2022Guru - Experienced User
For your devices not to contact the router first for the DNS info, you'd have to go into each individual device and change its default DNS server. Otherwise, they contact the router for the DNS ip address which gets forwarded to the pihole and then the pihole sends the address back. Its not something to change in the router or pihole but something in your devices for what you're trying to do.
