ant
Dec 09, 2020Prodigy
Netgear Orbi RBK753S' router sometimes slow to get an IP address for new connecting wifi devices?
I noticed this a few times like with printer, iPhones, etc. ever since I set up the new updated router and its two updated satellites yesterday afternoon PST (almost a whole day). It didn't matter ho...
Dec 09, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Do you have Armor enabled? Try disabling Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. CTS to 2347. Save settings and reboot the router and satellite(s).
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
- antDec 09, 2020Prodigy
My answers are in red inlined below.
FURRYe38 wrote:
V3.2.16.6_1.4.4
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Spectrum's leased E31N2V1 cable modem.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWell, it happens to next (e.g., room away) and far away (30 meters) to the router and satellites.
Do you have Armor enabled? Try disabling Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. CTS to 2347. Save settings and reboot the router and satellite(s).Nope. I don't want it.
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849The issue is getting an IP address from the router's DHCP even if the wifi signal is strong.
