desean
May 02, 2021Aspirant
Netgear Orbi RBK852 Static Route not working
Model: RBR850 (main unit of RBK852) Firmware: V3.2.18.1 I have another router (Xiaomi Mi AIoT Router AC2350) on 192.168.1.3 running another subnet under 192.168.2.x. (I do not want them to be on...
kolella
May 03, 2021Apprentice
Have you tried opening debug screen (192.168.1.1/debug.htm) click on "start capture" and after 10/15 seconds on "save debug file". The archive should contain a file called info.txt with routing table...
Is your static route present?
P.S. i think your metric should be 1 not 2 (but maybe i'm wrong)
- deseanMay 03, 2021Aspirant
Hi, thanks for pointing me to debug page, and I do see my static route in the output.
==========================route============================== Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default fnet1-f92-acces 0.0.0.0 UG 0 0 0 eth4 10.0.1.0 * 255.255.255.0 U 0 0 0 br-guest 143.158.81.0 * 255.255.255.0 U 0 0 0 eth4 143.158.81.1 * 255.255.255.255 UH 0 0 0 eth4 192.168.1.0 * 255.255.255.0 U 0 0 0 br-lan 192.168.2.0 192.168.1.3 255.255.255.255 UGH 1 0 0 br-lan
- kolellaMay 03, 2021Apprentice
Netmask is 255.255.255.255 should be 255.255.255.0 (and metric i've seen that netgear wants 2)
my 850 is in AP mode i've tried to add a static route 192.168.2.0/24:
==========================route============================== Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default 192.168.3.1 0.0.0.0 UG 0 0 0 br-lan 192.168.2.0 * 255.255.255.0 U 0 0 0 br-guest 192.168.2.0 192.168.3.27 255.255.255.0 UG 1 0 0 br-lan 192.168.3.0 * 255.255.255.0 U 0 0 0 br-lan
192.168.2.0/24 was overlapping with br-guest (added by orbi automatically) changed the static to 192.168.4.0/24 emd netmask is still correct
192.168.4.0 192.168.3.27 255.255.255.0 UG 1 0 0 br-lan
I have tried with netmask 255.255.255.0 and metric with either 2 or 3. None works though.
==========================route============================== Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default fnet1-f92-acces 0.0.0.0 UG 0 0 0 eth4 10.0.1.0 * 255.255.255.0 U 0 0 0 br-guest 143.158.81.0 * 255.255.255.0 U 0 0 0 eth4 143.158.81.1 * 255.255.255.255 UH 0 0 0 eth4 192.168.1.0 * 255.255.255.0 U 0 0 0 br-lan 192.168.2.0 192.168.1.3 255.255.255.0 UG 2 0 0 br-lan
Interestingly, one of my device under 192.168.2.214 shows up as a know device in the logs, but it cannot be connected while on 192.168.1.x and it doesn't show up on the Orbi web "Attached Devices"
config knowndevices '00CE39CF0F5B' option customizationModel '0' option defaultModel ' ' option defaultType ' ' option mac '00:CE:39:CF:0F:5B' option devTypeNameByNTGR 'Desktop' option devTypeIndexByNTGR '3' option devBrandByFing 'Orbsmart' option devOSByFing 'Windows' option detectEngine 'Fing' option devMByFing 'AW-09' option devTByFing 'DESKTOP' option devNameNtgr 'Orbsmart-AW-09' option model ' ' option connection 'wired' option conndevice 'device' option connectedOrbi 'Orbi Router' option defaultName 'HOMEAGENIUS' option devUsragent 'CaptiveNetworkSupport/1.0 wispr' option customizationName '1' option name 'HAG Smarter Switch' option customization '1' option customizationType '1' option type 'IoT (Generic)' option uasp '2' option devTypeNameByUser 'IoT (Generic)' option devTypeIndexByUser '11' option devNameUser 'HAG Smarter Switch' option devDPIName 'HOMEAGENIUS' option ip '192.168.2.214' option devConnStat '0'
