MarkyMarkUK
Aug 03, 2021Initiate
Netgear Orbi RBK853 + 2 Satellites:- Devices rarely connect to nearest satellite and keep dropping
Hi I have the Netgear Orbi RBK853 / RBR850 with 2 satellites. My house is an average 4 bed 2 (upstairs & downstairs) detached so you can estimate size. All units are on latest firmware V3.2.18.1_1.4...
- Aug 07, 2021
SOLVED
Just thought I'd come back here and say that I resolved the problem.
Just after FURRYe38 answered I thought I'd try something out before I went down the route of the suggestions and replying with all the details. I rebooted the Office satellite (next to the Quest 2), then I reset it too (with the button on the back). Then I switched it off, removed it from the network, rebooted the whole network (so there was only the Router and one satellite), then I went through the Adding a new satellite to the network option in the app. when done, BANG! Everything started acting as I thought it should do eg. devices starting connecting to the nearest satellite (both in the Gym and the Office and all connecting on the Router) and only the few devices near the Router, connected to it.
It's been like it for four days now, all devices connecting to the nearest satellite as expected, yipee!
Now the whole Orbi MESH system is awesome for me.
Aug 03, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
It's up to devices to pick and chose where they connect too. Not Orbi.
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor. Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
- MarkyMarkUKAug 07, 2021Initiate
SOLVED
- FURRYe38Aug 07, 2021Guru - Experienced User
Great to hear. Glad you got it working.
Enjoy.
