dale16
Nov 01, 2023Aspirant
Netgear Orbi RBR750
I don’t know what this location means above, but our router suddenly stopped working and we have no Internet. The modem is working fine and it is communicating with the Orbi router but nothing will wo...
dale16
Yes, everything was turned off with all wires removed with a waiting period. Also did this with the modem, which is working. Also confirmed the modem is communicating with the router. The ISP is providing. A couple of times we did get the Internet to come on but quickly go away.
CrimpOn
Nov 01, 2023Guru - Experienced User
It will help to be very specific about the equipment. There appears to be
- A cable modem from the Internet Service Provider (ISP)
- A router from the ISP
- An Orbi RBR router connected to the ISP router?
We know the modem is working because the ISP router provides internet service to devices connect to it?
But, the Orbi does not provide internet? (When the router is turned on, does it display a BLUE or MAGENTA ring light at the top for a couple of minutes?)
And this was all working previously?
- dale16Nov 01, 2023AspirantAll of the wires are in the correct places. The router does not have lights at the top. They are at the bottom. It’s been white with no other colors.
- dale16Nov 01, 2023AspirantWe know the modem is working because we spoke to the modem provider and they reset it at three different times and all three times it worked correctly and all the lights that were supposed to be on or on. Yes, this used to work before for a long time.
