dale16
Nov 01, 2023Aspirant
Netgear Orbi RBR750
I don’t know what this location means above, but our router suddenly stopped working and we have no Internet. The modem is working fine and it is communicating with the Orbi router but nothing will wo...
Nov 02, 2023Guru - Experienced User
is it this version? https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/New-RBR750-RBS750-Firmware-Version-7-2-6-21-Released/td-p/2333937/jump-to/first-unread-message
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
dale16
Nov 04, 2023Aspirant
Hi there, so I ended up getting a router from my Internet provider, but found out that it’s not going to work for me because I need satellites and it doesn’t have satellites which I realize now is the reason we originally got an Orbi router with two satellites. I’m going to work on this again with the Orbi on Monday. The part that confused me is using a laptop or something to connect to the modem or router. I don’t have a wire that will go from my laptop. I need to buy one. What is the name of the wire I need? Thanks!
