Mm91367
Dec 31, 2024Aspirant
Netgear Orbi rbr750p
Trying to setup and can never connect to the Orbi tried everything not sure what to do
CrimpOn
Dec 31, 2024Guru - Experienced User
Would help to know exactly how this setup is being done
- using web interface with a computer?
- using the Orbi 'app' when connected to the WiFi signal?
- Mm91367Dec 31, 2024AspirantTried both couldn’t connect either
- KevinLiTJan 10, 2025NETGEAR Moderator
Hello Mm91367 ,
Welcome to the NETGEAR Community!
I understand that you are having issues with completing the initial setup for your RBR750p.
Please visit the link below for a video guide on how to successfully setup your RBR750p (The model used in the video is different however, the setup process is the same for your RBR750p):
https://www.youtube.com/watch?v=BpnUMFgr-DM
Please keep me updated to the progress of this issue!
Best,
Kevin
Community Team
