yototogblo
Aug 15, 2022Tutor
Netgear Orbi RBR850 - Loses internet connection
I'm so tired of Netgear Orbi routers! I previously had the RBR50 which used to lose internet connection often. When it worked, the speed was great but when it didn't (which was way too often), it had...
yototogblo
Aug 18, 2022Tutor
I've replaced the cable multiple times so I very much doubt it's the cable that is the issue. It's connrcted directly (I'm not using a switch)
ekhalil
Aug 15, 2022Master
This looks like an issue with DHCP lease time from the Verizon router to Orbi, since Orbi is in AP mode.
Please test to set Orbi to use a static IP address from the Virizon LAN (has to be outside the DHCP range).
- yototogbloAug 15, 2022Tutor
Thanks but I use a static IP for both the router and satellite, not outside the DHCP range though. Why would it need to be outside the range? My range is from 192.168.1.2 - 192.168.1.254. I reserved 192.168.1.2 for the router and 192.168.1.3 for the satellite.
- Mikey94025Aug 18, 2022Hero
yototogblo wrote:Thanks but I use a static IP for both the router and satellite, not outside the DHCP range though. Why would it need to be outside the range? My range is from 192.168.1.2 - 192.168.1.254. I reserved 192.168.1.2 for the router and 192.168.1.3 for the satellite.
If you don't pick a static IP address outside the DHCP range then your Verizon router, which doesn't know you're using that address, may decide to assign it via DHCP to another device on your home network. This creates an IP conflict and both devices will have issues.
If you haven't already, try adjusting your Verizon DHCP range to start with 192.168.1.4 and also consider changing your Orbi to AP mode vs. Router mode. Let your Verizon router handle all the DHCP address assignment and avoid Double NAT. This also simplifies what your Orbi router is doing for your network, perhaps that will resolve your connectivity issues.
- yototogbloAug 18, 2022TutorThanks. Just to clarify, I assign the static IP from the Verizon router to the Orbi router and satellites' MACs. So I'm not giving the Orbi a static address from the Orbi so what you mentioned isn't a risk. To assign a static address to the Orbi from the Verizon router, it has to be within the DHCP range of the Verizon router.
The Orbi is already in AP mode and the Verizon router handles all DHCP assignments.
Also, something else to mention, I have in the past used the Orbi in router mode and had the same issues. It's been a while so maybe I should try it again. - FURRYe38Aug 18, 2022Guru - Experienced User
Be sure if you use the Verizon router with the RBR in router mode, use the Verizon routers DMZ for the RBR. Helps avoid the double NAT condition.
- yototogbloAug 18, 2022TutorPlan is to remove the Verizon router completely... I use tivo so don't need it for the cable box. Also don't use coax (gigabit service).
Be sure to check with the ISP if needed to see if removing there router is supported and to ensure there interconnecting device, i.e. ONT or what ever they are using is working and will allow a external 3rd party router to be connected to it.
- FURRYe38Aug 30, 2022Guru - Experienced User
Any progress on this?
