yototogblo
Aug 15, 2022Tutor
Netgear Orbi RBR850 - Loses internet connection
I'm so tired of Netgear Orbi routers! I previously had the RBR50 which used to lose internet connection often. When it worked, the speed was great but when it didn't (which was way too often), it had...
Aug 15, 2022Guru - Experienced User
If your having similar problems across two different systems, then you may have a problem up stream from the RBR if the RBR is showing PINK. That an indicator that the RBR has lost the connection to the ISP modem/ONT or the modem stopped giving services to the RBR or there maybe a bad cable.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Have the ISP check there logs for any issues seen on there side when this happens.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Update FW as well:
yototogblo
Aug 15, 2022Tutor
Thanks for the response
Just to clarify, the RBR50 wasn't turning purple. The issue with that was the satellite kept losing internet connection while staying connected to the router. So my devices connected to the satellite would have very slow or no internet connection. I eventually had to connect it to a smart plug to restart the satellite daily at 3am. So different issue with that router but equally frustrating.
I've changed the cable between the Verizon router and the Orbi a few times and I use CAT6. The ISP has checked a few times and it's always fine. Devices connected to the Verizon router via ethernet are always fine also. In fact, when I switch to using the router's wifi, I never have issues. So this is localized to the RBR850 and not an ISP or FiOS issue.
Home is 1450 sq ft. Distance between router and satellite is about 30ft. Using Auto on 2.4GHz and 48 on 5GHz,
I live in a condo so have a decent amount of neighbors. I live at the end of the hall though so fewest neighbors of anyone else. Seeing probably about 20 other WiFi networks with 5 strong signals.
Thanks for the firmware update link. The last firmware update did nothing to fix my issues (maybe even made it worse). Don't see anything in this firmware notes but will try this one and hopefully, it fixes some issues.
- yototogbloAug 15, 2022Tutor
This should have said
"In fact, when I switch to using the Verizon's router's wifi, I never have issues. So this is localized to the RBR850 and not an ISP or FiOS issue."
- FURRYe38Aug 15, 2022Guru - Experienced User
For that size of home, you only need the RBR. Having the RBS maybe too much.
Does the RBR still loose the connect if you turn OFF the RBS?
What channels are you using? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.Having that many wifi neighbors may also be causing problems as well. You might turn down the power output of the RBRs wifi radios from 100% to 50% or even 25% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
I have some very poor network spots (shape of home) hence why I got a mesh. I haven't tried turning off the RBS850 but don't see that as a solution. There's still about 30ft between router and satellite (our ethernet spot is at one end of home so can't put router in center and cover whole house).
Let us know how it goes after you try the suggestions.
