bubbub
Sep 20, 2021Aspirant
Netgear Orbi RBR850 is not compatible with Apple iCloud Private Relay
My updated Apple MacBook running macOS12 (beta) is reporting my router is incompatiible with iCloud private relay. This is a new privacy feature for Apple products. I imagine Netgear is aware of this...
Sep 22, 2021Guru - Experienced User
File a bug report to Apple using the feedback and let Apple know about this. Something they need to look at.
bubbub wrote:
My updated Apple MacBook running macOS12 (beta) is reporting my router is incompatiible with iCloud private relay. This is a new privacy feature for Apple products. I imagine Netgear is aware of this new feature and hope the firmware supports Apple initiative soon.
- bubbubSep 22, 2021Aspirant
Thanks for your response and suggestion. Since I am using a beta service on a beta OS (macOS12), I have and will describe my experiences with these Apple systems via their feedback conduits. Since I haven't seen reference to QUIC on Netgear reference material I think its proper to ask Netgear about how they plan to support this exciting privacy initiative.
- FURRYe38Sep 22, 2021Guru - Experienced User
Something Apple and NG will have to work out.
- Blanca_OSep 22, 2021NETGEAR Employee Retired
Hi bubbub
Welcome to NETGEAR Community!
Thanks for bringing this to our attention. We'll have the information forwarded to our product teams.
May we please know the firmware version installed?
For Circle and SPC, we are already working on a solution for this. Here's a reference KB link: https://kb.netgear.com/000064018/
Blanca
Community Team
- raven_auSep 22, 2021Virtuoso
bubbub wrote:Thanks for your response and suggestion. Since I am using a beta service on a beta OS (macOS12), I have and will describe my experiences with these Apple systems via their feedback conduits. Since I haven't seen reference to QUIC on Netgear reference material I think its proper to ask Netgear about how they plan to support this exciting privacy initiative.
The Apple initiative I've heard of sounds more like privacy invasion to me.
Just what do you think Negerar needs to do for QUIC?
There might be in kernel Linux support at some point but existing routers are unlikely to update their kernels so it's use will be a bit slower than it could be if, in fact, there is anything on the router itself that needs to use it which is very unlikely.
- riorSep 22, 2021TutorFlagging I have the same issue on an iPhone on iOS 15. iCloud private relay does not work on my RBR50 router (latest firmware) but it does work on 4G and also a TP-Link router I tried.
