bubbub
Sep 20, 2021Aspirant
Netgear Orbi RBR850 is not compatible with Apple iCloud Private Relay
My updated Apple MacBook running macOS12 (beta) is reporting my router is incompatiible with iCloud private relay. This is a new privacy feature for Apple products. I imagine Netgear is aware of this...
bubbub
Sep 22, 2021Aspirant
Thanks for your response and suggestion. Since I am using a beta service on a beta OS (macOS12), I have and will describe my experiences with these Apple systems via their feedback conduits. Since I haven't seen reference to QUIC on Netgear reference material I think its proper to ask Netgear about how they plan to support this exciting privacy initiative.
Sep 22, 2021Guru - Experienced User
Something Apple and NG will have to work out.
- Blanca_OSep 22, 2021NETGEAR Employee Retired
Hi bubbub
Welcome to NETGEAR Community!
Thanks for bringing this to our attention. We'll have the information forwarded to our product teams.
May we please know the firmware version installed?
For Circle and SPC, we are already working on a solution for this. Here's a reference KB link: https://kb.netgear.com/000064018/
Blanca
Community Team- bubbubSep 23, 2021Aspirant
The RBR850 is running
V3.2.18.1_1.4.14This issue is not yet consistantly repeatable. I received the error after applying the most recent BETA to my MacBookPro (12 Beta (21A5506j)) and upon upgrading my iPhone to iOS 15 (19A356). I received the error as a notification the first time. I have not seen that notifaction again. After power cycling the devices with Private Relay or Address enabled, the first attempt to load an uncached webpage seems to work fine, currently. Earlier, as I switched iCloud Private Relay (MacBookPro) or "Private Address" (IPhone 12) OFF and ON, I would I note network disconnects with some instances, but not with others. I gave each instance time to reconnect to the wireless network before observinbg results.
- FURRYe38Sep 23, 2021Guru - Experienced User
Since you saw this after applying the OSX Beta, would be something to file a feedback report to Apple about. Let them now what worked before and now it's not. You on a beta and thats Apples realm.
