WLS's avatar
WLS
NETGEAR ORBI RBR850
hi
My client in there house has a Netgear ORBI rbr850.
Firmware v4.6.9.11_2.3.5.
We are trying to connect a video door entry intercom system to it, the system needs to connect to the internet to connect to the cloud so then the client can use the mobile phone app to receive calls from the intercom & open the door. The door entry system connects to the router via Wi fi ok but it can't connect out to the cloud & internet.
The door entry system does work has i used my mobile phone as a hot spot & it connected to the cloud straight away.
The door entry system is Hikvision.
Any suggestions please.
kind regards
  • plemans's avatar
    What modem/gateway is the orbi connected to? Double nat's can cause issues like that.
    • WLS's avatar
      WLS
      hi
      the client said he has a standard virgin router set into modem mode
    • WLS's avatar
      WLS
      hi
      thanks for the reply
      he said he has a standard virgin router setup as modem mode.
