ChrisBeauchamp
Jan 27, 2021Initiate
Netgear Orbi RBR850/RBS850 & Lennox iComfort S30 Intermittently Drops Connection
Found this post on a previous and closed thread. Credit goes to mcb13 (poster). This seems to work so far. "I now see three SSIDs and the S30 will not connect to any of the three. If I tap the...
- Jan 28, 2021
ChrisBeauchamp
Feb 04, 2021Initiate
Solution works for me after 1 week. Lennox is looking into the issue. Once root cause is established I'll know better if it is a Lennox issue or Netgear issue.
vajim
Feb 05, 2021Master
ChrisBeauchamp wrote:Solution works for me after 1 week. Lennox is looking into the issue. Once root cause is established I'll know better if it is a Lennox issue or Netgear issue.
Thanks for the update
