rickerr63
May 01, 2023Aspirant
NETGEAR ORBI ROUTER ADMIN PAGE IS TOTALLY BLOCKED BY CHROME & SAFARI
I have the netgear orbi mesh network. I now find that I just cannot access the router homepage. I get insecure sight warnings and internal server error 500 if I try to push through so I can follow ...
- May 04, 2023Thanks I will try edge , but like you I don’t use it for anything else!
May 01, 2023Guru - Experienced User
Be sure to clear all browser caches before entering the routers web page.
What Orbi model do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
- rickerr63May 01, 2023Aspirant
Thanks,
Did all this and it works to the point where I can access the router admin page again, but still getting security warnings. I tried the advice on installing a certificate but there is an error on that saying the signature algorithm is wrong. If I set web services management to use https i still get the warnings.
I am n RB750 with two satellites and firmware version V4.6.14.3_2.3.12
- FURRYe38May 01, 2023Guru - Experienced User
Warnings are self assigned cert info from the browser. You can OK thru those messages. I don't use HTTPS as it's not needed for my needs.
Thanks again but Im not sure I have installed the cert as chrome doesn't behave exactly as per the instructions I found:
