rickerr63
May 01, 2023Aspirant
NETGEAR ORBI ROUTER ADMIN PAGE IS TOTALLY BLOCKED BY CHROME & SAFARI
I have the netgear orbi mesh network. I now find that I just cannot access the router homepage. I get insecure sight warnings and internal server error 500 if I try to push through so I can follow ...
- May 04, 2023Thanks I will try edge , but like you I don’t use it for anything else!
rickerr63
Thanks,
Did all this and it works to the point where I can access the router admin page again, but still getting security warnings. I tried the advice on installing a certificate but there is an error on that saying the signature algorithm is wrong. If I set web services management to use https i still get the warnings.
I am n RB750 with two satellites and firmware version V4.6.14.3_2.3.12
May 01, 2023Guru - Experienced User
Warnings are self assigned cert info from the browser. You can OK thru those messages. I don't use HTTPS as it's not needed for my needs.
