rickerr63
May 01, 2023Aspirant
NETGEAR ORBI ROUTER ADMIN PAGE IS TOTALLY BLOCKED BY CHROME & SAFARI
I have the netgear orbi mesh network. I now find that I just cannot access the router homepage. I get insecure sight warnings and internal server error 500 if I try to push through so I can follow ...
- May 04, 2023Thanks I will try edge , but like you I don’t use it for anything else!
May 01, 2023Guru - Experienced User
Warnings are self assigned cert info from the browser. You can OK thru those messages. I don't use HTTPS as it's not needed for my needs.
rickerr63
Thanks again but Im not sure I have installed the cert as chrome doesn't behave exactly as per the instructions I found:
- RafSMay 03, 2023Apprentice
Try using Edge. I reset my system a couple of weeks ago and needed to load the firmware on each satellite and no matter what I did, it would not log into the satellite via Firefox, Chrome, Safari. I tried for over an hour and finally gave up and then I figured, why not try Edge, and sure enough that silly browser that I use for absolutely nothing was able to log into each satellite without any issues. I don't know what weird deal Netgear made with MS but I've never seen this happen before and I've always used one of the other 3 browsers to access the router and satellites.
- rickerr63May 04, 2023AspirantThanks I will try edge , but like you I don’t use it for anything else!
