Tcrus
Apr 30, 2020Luminary
Netgear ORBI showing connected but no wireless connection
My ORBI RBR850 WIFI 6 has been working flawlessly for 6 months and all of a sudden I am getting no wireless connection. I performed a facotry rest, reconnected and yet it shows my wireless SSID. I am...
- May 01, 2020
Well it looks like it was infact my Netgear Modem CM1000. I am not sure exactly what was wrong with old one but new one is working. I suspect old was faulty or Comcast somehow deregistred my MAC or altered something because after they removed the old modem and registred new one my ORBI started working and I had wired connections again. Man that was frustrating, easily spent 10-15 hrs doing work arounds and it ended up being a possible broke modem........... Having no internet during covid with kids in house is no fun. Thanks for the help
May 01, 2020Guru - Experienced User
Let us know. I also have an AsRock as well. Working so far. Built back in 2018.
Tcrus
May 01, 2020Luminary
- FURRYe38May 01, 2020Guru - Experienced User
Glad you found the culprit. Modems can go bad.
Mark your thread as solved so others will know.
Enjoy. :smileywink:
- TcrusMay 03, 2020LuminaryWell the problem is back, internet worked fine for about 10 hrs after changing modems but then had a few dropped connections and now nothing. New modem so that can’t be it. Going to swap the orbi router out for the new ax8 again and if that’s not it then it HAS to be the Motherboard or something with my isp provider. Don’t know what else it could be
- kildareMay 03, 2020Luminary
If your devices are correctly wirelessly connected but you can't reach the Internet you probably might have TCP/IP addressing problems/conflicts, maybe you're using some DHCP settings which overlap with your carrier's configuration.
You shoud check TCP/IP settings (IP, Gateway, DNS) as seen on your wireless devices.
The most likely setting that might have conficts is the Gateway address.
I can reach the internet just not consistantly. I did go with a static DNS since looking in my event viewer I did see some DNS client event warnings. Well see how or if that makes a difference. Warning -Event ID 1014 - Name resolution for the name ad.afy11.net timed out after none of the configured DNS servers responded.
About DNS, some wireless devices might be using the Private DNS setting that may cause intermittent blocks.
Moreover, recent wireless devices implement by default the random MAC address functionality which might confuse and eventually saturate the DHCP servers.
Makes sense but what would be the fix for this?
So I switched back to the ORBI and its connected so well see for how long. Even though before it would not connect. This is getting confusing. So here is the long story short incase someone decies to decipher this ordeal
My WIFI started dropping out and eventually no WIFI connection. I do have a connection through hardline directly from modem to CPU. I replaced the old router (when I say old I mean the $600 ORBI RBR850, 6 months old) to rule that out
with the AX8 and no connection still. OK maybe its the modem so I swapped out my CM1000 with a new CM1000 and registred MAC with IP and went back to the ORBI and BAM it worked great for about 10 hours, then the same issue. I did a couple modem resets from the ISP when the signal dropped through the day and it seemed to refresh the WIFI signal. Then the WIFI totally stopped working, nothing but when i disconnected from the router and hardline worked just fine. So I just swapped out the ORBI again for the AX8
and WIFI is working for now. I have some decent experience with computers IT degree and several certs so I am not a complete idiot when it comes to trouble shooting just half an idiot BUT what the hell is goin on. It has to be ORBI went bad but why wasnt the AX8 working initially with the old modem (CM1000)? Or is it the motherboard lan ports that are going bad but the hardline works all the time just not in combination with the router(s). My network settings are basic e auto obtain IP/DNS. My ISP provider tells me nothing is wrong on there end because when modem plugged straight into the CPU I have no problems BUT when I registered the new modem with the ORBI it worked great for about 10 hours.
I hope this sounds somewhat clear and I would really appreciate any ideas and reccomendations. What are you leaning towards as problem or feel free to add own conclusions
1. ORBI went bad or on its way out maybe the reason it works then doesnt? The AX8 did not work either when I first installed it but does now when its installed.
2. Motherboard LAN ports bad or on there way out?
3. Router settings (but have not changed)? ip and dns are obtained auto but have tried statically too havent seen a change
4. ISP service something is wrong but hardline always works just not in combo with routers - TcrusMay 03, 2020Luminary
It seems that un-enabling AX and having a static DNS 8.8.8.8 I havent seen any problems as of yet (using ORBI RBR850). Not holding my breath. Also using firmware 11.2. This is odd since I had not one problem in 6 months and then out of the blue, I did reinstall my components into a new case but that would not have anything to do with this, no other changes have been made except I did a fresh windows install after the initial problem happened.
- RBK853onATTMay 03, 2020Tutor
I've been having the exact same issues with a 2 month old RBK853 system with an AT&T 1G fiber connection. It has been dropping offline for 2-5 minutes at a time since the install, but for the first month I tried to troubleshoot on my own with various settings (RTS/CTS, DNS, Modem changes, etc.) For the past few weeks I've been working with Netgear Level 2 support. We tried all of the standard mitigations to no avail. Then loaded the new 3.2.11.2 firmware on Wednesday and things seemed to be fixed on Thursday/Friday. But then Saturday evening I had one drop followed by multiple drops on Sunday morning, with one requiring a power cycle to reestablish a connection.
I thought I'd register and let you know that you all are not alone. My L2 contact in tech support has been pretty good, so I'll let you know the steps we're taking to (hopefully) resolve. At this point I'm thinking that it may be a hardware issue that needs to be RMA'd.
Thanks for the info, good to see I am not alone here. It's just insane how it will work then nothing, even with resetting it to factory settings it shows as connected but no WIFI. I am on comcast gigabit connection and it went smooth for 6 months then this. No WIFI when kids are off from school is not good. I am leaning towards hardware issues with the ORBI but will keep trouble shooting it until I can solve this problem.
- Mikey94025May 03, 2020Hero
- Have you already set the CTS/RTS thresholds to 2347 for both 2.4Ghz and 5Ghz (website Advanced...Wireless Settings)?
- [ Sorry, I see now in a later post you already tried this ] If it's a DNS issue (but this doesn't really make sense) then you can factor it out by using Google DNS instead of your router and ISP: https://developers.google.com/speed/public-dns. In Advanced...Internet Setup change DNS address from Get Automatically to DNS servers 8.8.8.8 and 8.8.4.4
- Also, is your Comcast mode bridged to the Orbi or are you using it with double NAT? This also shouldn't affect your wireless connectivity, but another variable you can play with.
I did change the CTS/RTS threshholds. I changed the DNS just because of multiple errors in event viewer just one more thing to eliminate. There is just no consistancy in the errors and I cant replicate it but when it happens its almost like the ports are broke on either the router or MB. In settings there are only so many things it can be so makes me believe its the router and or MB. Time will tell, I guess but its very annoying for sure. It could also be my ISP because when it does happen its almost like my MAC address is not being registered. I did have my first network cable go out on me a few weeks ago and god that took forever to solve, simpliest fix seems like the hardest to find or at least overlook. If it is the MB or router it would be my first to ever go out and ive been through lots.
- FURRYe38May 03, 2020Guru - Experienced User
Is the ASRock PC the only device experiencing this problem is is all of your devices doing this?
Asrock pc is my main pc/server that connects all my devices. I have another pc thats hard lined in and it works but again the hardline works when the router does not on the Asrock. The hardline internet has worked on every machine so maybe that can rule out the MB. I have seen the error check your network cables/broken cable consistantly when I have this WIFI problem, sometimes an ISP reset fixes the problem other times it does not which makes me think its MAC related or router hardware
What I'm asking is that do all other devices, wired and wireless connect to the internet with out problems? or do they exhibit the same problem as your ASRock PC does?
Yes they kinda do exhibit the same problem BUT nothing has been consistant. Sometimes the ISP says modem is offline and nothing works (new modem) and a refresh signal fixes it. Other times it shows online and WIFI does not work for any device even though it shows my SSID and connected, then the wired connections will work but the WIFI does not. Sorry if I sound confusing but its not a clear cut answer, I am just as confused lol
Ok, ya is kinda non consistent which makes it hard.
Do you have you old router. Something to try with your old router to help rule out Orbi. Connect it up. Turn OFF Orbi. Test. See if same thing still happens. Wired and wireless with new modem. If it does, Then seems that something at the modem or upstream is causing problems.
If the ISP is seeing the modem off line as well, I would think there is a problem between the modem and there side...
In my case: I've also tried changing the CTS/RTS thresholds and DNS settings, as well as running in both router and AP modes. Nothing has solved the problems. When an outage occurs, I can verify that the internet from the ISP (AT&T) remains active via a PC hardwired to the modem/router. Everything on the Orbi network remains attached to the wireless signal but nothing is reachable - even the Obi router at 10.0.0.1 (while in router mode). I've even hard configured a Mac to use Cloudflare's DNS, but the outages still occur. So it doesn't appear to be a DNS issue. Also, I have a few items hard wired to the router or satellites via Cat6, and those go down too - so it's not a wireless problem. The outages seem to come in bunches, but there is no consistency to them - sometimes they're minutes apart, sometimes hours, or days. One of the recommended solutions from Netgear support was to roll back the firmware to x.9.2 but interestingly this seemed to fail. We ended up upgrading after x.11.2 was released.
I haven't had time to talk with Netgear support since the firmware upgrade failed, but hopefully in a few hours.
I recommend making a new post about your problem. This thread is already kind of confusing and hard to keep track of. Lets make a new post and we'll help you out there. Thank you.
RBK853onATT wrote:In my case: I've also tried changing the CTS/RTS thresholds and DNS settings, as well as running in both router and AP modes. Nothing has solved the problems. When an outage occurs, I can verify that the internet from the ISP (AT&T) remains active via a PC hardwired to the modem/router. Everything on the Orbi network remains attached to the wireless signal but nothing is reachable - even the Obi router at 10.0.0.1 (while in router mode). I've even hard configured a Mac to use Cloudflare's DNS, but the outages still occur. So it doesn't appear to be a DNS issue. Also, I have a few items hard wired to the router or satellites via Cat6, and those go down too - so it's not a wireless problem. The outages seem to come in bunches, but there is no consistency to them - sometimes they're minutes apart, sometimes hours, or days. One of the recommended solutions from Netgear support was to roll back the firmware to x.9.2 but interestingly this seemed to fail. We ended up upgrading after x.11.2 was released.
Gonna start a new thread but I think wre have the same issue, i have devices connected to the router hardlined and they also do not respond passing through router, who is your ISP?
RBK853onATT wrote:When an outage occurs, I can verify that the internet from the ISP (AT&T) remains active via a PC hardwired to the modem/router. Everything on the Orbi network remains attached to the wireless signal but nothing is reachable - even the Obi router at 10.0.0.1 (while in router mode)
- Can you explain how your ISP signal can be multiplexed to both your hardwire PC and the Orbi? So you're not using bridge mode and instead your modem is also a router. Then you have double NAT and while this is not recommended, it also works just fine for general internet and browser access (I did this for years).
- I don't think the Orbi router should not be 10.0.0.1 - For me that is my Comcast modem, even if I'm running in bridge mode. The Orbi router should be at the IP address set in Orbi Advanced...Setup...LAN Setup, LAN TCP/IP Setup.
- You should also test connecting devices by network cable to the Orbi, so you can distinguish if this is an Orbi wireless or Orbi connectivity (affecting both Orbi wired and Orbi wireless) issue.
- Sorry if you've already tried this, but it should be easy to diagnose if this is the Orbi or the ISP modem.
- If your modem is setup for router (not bridge) and the PC hardwired to the ISP modem has issues then it is not the Orbi.
- If your PC does not have issues but clients connected to the Orbi (wired to Orbi or wireless) have issues then that points to the Orbi,
- Note that in bridge mode you cannot connect multiple devices to your modem, only one.
If so, this kind of indicates a problem up stream from the RBR in AP Mode.
Tcrus wrote:Gonna start a new thread but I think wre have the same issue, i have devices connected to the router hardlined and they also do not respond passing through router, who is your ISP?
I agree with Tcrus that the issue appears to be the same, which is why I posted to this thread. I'm working with Netgear L2 support which so far has been good so I'm not necessarily looking for help here - but rather just wanted to provide the information I'm receiving to others who appear to be in the same boat. (Thanks though!) I'll create another thread if or when the help is needed - otherwise I'll provide the resolution when I receive one. In the interim, I'll answer the below questions:
1) AT&T doesn't provide full bridge mode unfortunately but rather a DMZ+ mode only. That said, I don't use it as in spite of the name it seems to create other issues with certain forms of video traffic (illogical I admit, but that's AT&T.) So you are correct that if I run the Orbi in router mode I'm double NAT'd. This is only an issue if there is a conflict on the subnets or unnecessarily complicated if any sort of port forwarding is needed. But in this case I don't have any firewall pinholes and I've verifiied that the assigned subnets are completely different. BUT in any event I've run the Orbi in both AP and Router mode and documented the drop outs in both cases. I prefer router mode for a variety of reasons but have run AP mode for weeks - the dropout issues seem the same in either configuration.
2) I'm not sure what to tell you here - the RBR850 does absolutely use a default out of the box IP of 10.0.0.1 when in router mode. Or at least mine does. I've tried the other subnet range secondarily offered in the GUI as well but this also didn't resolve the problem. (It logically shouldn't unless the problem were a conflict.)
3) I do have a number of devices hard wired to the RBR850 as well as one of the RBS850's. These wired devices also drop when an event occurs.
4) I agree with your logic, and I've tried all of this. The dropouts seem to happen randomly but when they occur I'm often in a good position to diagnose as I'm working from home these days. The PC hardwired to the AT&T router is always online and functional, and the units connected via hardwire *and* wireless all drop offline from the Orbi. It's not a DNS problem - the whole connection is down. (I've also tried configuring the Orbi to use the Google or Cloudflare DNS services - both are faster that AT&T's but the drops continued.) When an outage occurs, I can't even reach the internal Orbi interface from either wireless or hardwired connections. Oddly, the WiFi network seems to remain "up" as my computers/phones remain attached to it. So not a total crash and reboot. I've also checked the logs in both the AT&T and Orbi systems and don't see any obvious error codes. I do see the AT&T router logging disconnects/reconnects from the RBR, but the AT&T system isn't throwing any errors - it's just a "IP XXX reconnect" type message. And at the end of the day this AT&T router has been working flawlessly for 2+ years with my old Apple system. I grant that it's theoretically possible that it broke at exactly the same time as the Orbi upgrade, but seems pretty unlikely.
Anyway, I was really pulling for the new 3.2.11.2 firmware to resolve the issue - the tech support help indicated that it would likely do so. And things were better for around 48 hours, but then the drops popped back up again. So I'll let you all know if/when we find a path through!
- BanditoMay 04, 2020Luminary
When the 'outage' occurs, have you tried some very basic troubleshooting steps? Here's what I'd try:
1. Verify that the clients have a valid IP address from the router and not a self-assigned address in the 169.254.x.x range. If you have a self-assigned IP address, this would indicate a DHCP issue.
2. Ping the RBR850 (router) to ensure that you can 'see' it via the network. If you can't Ping it, then there is a fundamental problem with the network itself not passing data.
3. Ping an Internet address, such as www.google.com. If you get a response, then things should be working correctly. If not, then there is likely a DNS issue.
These three basic steps should give you a lot of insight into what's happening on your network.
What AT&T gateway are you using? Mine is a BGW210 and it has a Pass-through mode that provides a raw Internet connection to each of the four LAN ports on the back. This is really nice as you can add other devices and not just the Orbi to the gateway to monitor the raw Internet performance at the gateway itself. Just remember that this is a raw unfiltered connection, so if you're going to place a PC on it full time, you should enable a firewall and take all appropriate precautions.
If I am understanding things correctly, when the 'outage' occurs, the Orbi's radios are still broadcasting a signal and your clients remain attached to the router, but get no Internet access. When this has occurred, have you tried to communicate just within your internal network from one device to another? Does that still work? This would indicate whether or not the router is still passing local traffic.
Hopefully, you've already gone through these basic troubleshooting steps, but sometimes it doesn't hurt to revisit the fundamentals.
